Max_Maas
Mar 11, 2016Tutor
ReadyNAS 102 - ReayCloud won't turn on.
Dear Support, I see the old tread: https://community.netgear.com/t5/ReadyCLOUD/ReadyCloud-won-t-turn-on/m-p/1018938#M2041 has been signed as closed. Why? The problem is not solved. In the...
- Mar 17, 2016
You should be able to turn on ReadyCLOUD again now.
Mar 11, 2016Guru - Experienced User
has been signed as closed....
Why? The problem is not solved...
It was actually Synergie's thread (though you posted to it) - and the marked solution was for Synergie's problem (which is not the same as yours). You can open a new thread for your problem.
Also this is a community forum, not a Netgear support forum (though several Netgear support people are active here).
Note that ReadyCloud is changing significantly in 6.5.0, you can see the details in the beta thread.
mdgm-ntgr
Mar 16, 2016NETGEAR Employee Retired
Max_Maas I haven't heard back from you yet. Did you get a chance to read my PM?
