PLeyro's avatar
PLeyro
ReadyNAS 102 - ReayCloud won't turn on with Firmware 6.5.0
Hi, I see the old tread: https://community.netgear.com/t5/ReadyCLOUD/ReadyCloud-won-t-turn-on/m-p/1018938#M2041 has been signed as closed. Why? The problem is not solved. In the meantime I re...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Jun 15, 2016
    This is a problem where if it occurs it needs to be fixed remotely. The fix should then survive firmware updates.
    Applied the correct serial number and rebooted. It appears to now be fixed.
ProSupport for Business
