PLeyro
Jun 10, 2016Aspirant
ReadyNAS 102 - ReayCloud won't turn on with Firmware 6.5.0
Hi, I see the old tread: https://community.netgear.com/t5/ReadyCLOUD/ReadyCloud-won-t-turn-on/m-p/1018938#M2041 has been signed as closed. Why? The problem is not solved. In the meantime I re...
- Jun 15, 2016
This is a problem where if it occurs it needs to be fixed remotely. The fix should then survive firmware updates.
Applied the correct serial number and rebooted. It appears to now be fixed.
PLeyro
Jun 11, 2016Aspirant
Hello JennC,
Thanks for your quick reply.
I will send a PM to mdgm-ntgr more quickly and follow its instructions.
Long live the community!
Pascal :-)
mdgm-ntgr
Jun 15, 2016NETGEAR Employee Retired
