perlundin66
Aug 16, 2016Tutor
ReadyNAS 102: When using ReadyCLOUD on my desktop I get the message "No volumes or USB disks"
Hi. When using ReadyCLOUD on my desktop I get the message "No volumes or USB disks" trying access my information on my ReadyNas. OS 6.5-0. Status: In good shape. I have tried to get a solution via t...
- Sep 15, 2016
Solution found! I had to delete all links in ReadyCLOUD to my NAS. Then, at home on my LAN, I had to reconnect the NAS again. And then....the disks are back! Hopefully this can help others with the same problem. :-)
perlundin66
Aug 17, 2016Tutor
Hi JennC. Thanks for the quick response.
It looks like this:
Aug 17, 2016Guru - Experienced User
perlundin66 wrote:
Hi perlundin66 These links are invalid (they appear to be links to gmail???)
Please just click on the image link, and browse to the image on your PC. Then upload it.
- perlundin66Aug 17, 2016Tutor
Hi StephenB. I'll try it...
Looks like this:
Hopfully this will work better :-)
BR. Per Lundin
- StephenBAug 17, 2016Guru - Experienced User
Those links work. But you appear to be browsing to readycloud, and JennC wanted to see the version of the readycloud app (which is an installed program).
Hmmm... here is someting fishy...
The ReadyCloud folder is empty...
...and the icon is grey...
...but I have installed and reinstalled the program several times...
When I try to run it, nothing happens. I have also tryed to run it as administrator.
OS is Windows 10.
BR: Per
