perlundin66
Aug 16, 2016Tutor
ReadyNAS 102: When using ReadyCLOUD on my desktop I get the message "No volumes or USB disks"
Hi. When using ReadyCLOUD on my desktop I get the message "No volumes or USB disks" trying access my information on my ReadyNas. OS 6.5-0. Status: In good shape. I have tried to get a solution via t...
- Sep 15, 2016
Solution found! I had to delete all links in ReadyCLOUD to my NAS. Then, at home on my LAN, I had to reconnect the NAS again. And then....the disks are back! Hopefully this can help others with the same problem. :-)
JennC
Aug 23, 2016NETGEAR Employee Retired
Hello perlundin66,
This must be something is blocking the app on this computer since the mobile see the NAS volume, that means the NAS settings are fine. Maybe lowering down or turn off the security.
perlundin66
Sep 15, 2016Tutor
- JennCSep 16, 2016NETGEAR Employee Retired
Hello Perlundin66,
Thank you for letting us know that you have found a solution.
Please feel free to post any comments, suggestions or questions. We appreciate your contribution!
