pandiyanr
Nov 13, 2019Aspirant
ReadyNAS 204 degreat to dead
Dear All, PFA Please let me know it's possible to recover data. Thanks Pandiyan
pandiyanr
Nov 14, 2019Aspirant
Hi,
4x 4 TB Hard disk installed and configure in RAID 5.
Thanks
Nov 14, 2019Guru - Experienced User
How much data (if any) can be recovered depends on what went wrong.
As Marc_V says, if you want to recover it on your own, you'd need to put the disks into a Windows PC, and use RAID recovery software that supports BTRFS. The only package I am aware of that does is ReclaiMe ( https://www.reclaime.com/ ). You can install it before purchase, and see if it can recovery anything.
The other option is to use paid support (via my.netgear.com), and purchase a data recovery contract. Terms are here: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
Marc_V also offered to take a look at your log zip file first - which wouldn't cost anything, and would give you some idea of whether data recovery is likely to succeed. I suggest that you take advantage of that. Download the full log zip file from the NAS web ui, and then store that in cloud storage (google drive, dropbox, etc). Send Marc a private message using the envelope icon in the upper right of the forum page that includes a downloadable link to the zip. Don't post it publicly.
