Falstaff
Dec 07, 2021Aspirant
readynas backblaze b2 problem connection
I am on OS 6.10.6. Every time I try to connect to Backblaze b2 via the s3 interface, I get an error "unable to read amazon bucket list." This is in the system log: Dec 07 12:35:17 phoenix libng...
Timtech
Jan 24, 2022Apprentice
Has anyone heard back from NetGear on this issue?
I just noticed my Backblaze backup stopped around mid December without any error that I could see. I did upgrade the ReadyNAS OS around December 20th after that time and have since reverted to the Hotfix 1 which worked great for months. Now Backblaze won't work with the new OR the old OS.
I too contacted BackBlaze and they mentioned that we must be on V4. I think Backblaze changed something on their end, since I reverted to the older OS, it should work again but it doesn't.
Anyone have any ideas? Does anyone know where the logs are stored for the S3 backup section and I can see what the logs say when trying to connect?
bvbbvb
Jan 24, 2022Guide
Since I don't own a product under warranty, I'm apparently cut off from any opportunity to communicate with Netgear support. All I hear about this significant problem is crickets...
