saulatz
Oct 11, 2018Aspirant
ReadyNAS not able to connect to Readycoud
Hi, I'm not able to connect my ReadyNAS to Readycloud. If I go to "cloud" page while administrating the ReadyNAS, and switch on "ReadyCloud" service, it gives me an error: "Something is preventing th...
Kamwong
Oct 17, 2018Aspirant
I have the Sam problem too. Please help.
- JohnCM_SOct 27, 2018NETGEAR Employee Retired
We had an issue with the ReadyCLOUD server two weeks ago but that was already fixed. In most cases, you need to reboot the NAS to reconnect to ReadyCLOUD. Are you still not able to connect to ReadyCLOUD?
- saulatzOct 31, 2018Aspirant
Hello,
I'm still not able to login. Now, when I'm trying to switch on the RadyCloud service under "cloud" pane in "admin" page of NAS, I get the error: "Something is preventing the ReadyNAS from connecting to ReadyCloud server. Please reboot your ReadyNAS and try again". I have tried to reboot but its the same issue. So basically the ReadyCloud service is "off".
But I have cloud users showing under the "account" pane. If I try to remove the cloud user here, I get this error" This device is joined to ReadyCloud. To remove a user, visit ReadyCloud." I'm confused now as the ReadyCloud service is OFF, so I don't how the NAS is connected to the cloud?
Please help. Thanks!
Just to add, our ISP is using NAT firewall to shield us from outside network. So my IP address will not be visible to the outside world. I hope that's not a problem?
- KamwongOct 31, 2018Aspirant
I still have the problem.
- StephenBOct 31, 2018Guru - Experienced User
Check that port 6300 is actually open using http://www.canyouseeme.org/ on a PC that is connected to the same router the NAS is connected to.
