BWF-IT
Jan 08, 2016Aspirant
ReadyNas Remote device shows offline when on WAN
Hi I'm trying to setup ReadyNas remote for a client, but have been unsuccessful so far. ReadyNas remote is installed on the NAS unit and enabled. The remote client is installed on the workstation...
mdgm-ntgr
Jan 08, 2016NETGEAR Employee Retired
That would be one option to try to see if you can get it working.
- JennCJan 08, 2016NETGEAR Employee Retired
Hello BWFT-IT,
Welcome to the community!
Also, try disabling firewall/security software. And add 8.8.8.8 as secondary DNS in the network settings.
- BWF-ITJan 09, 2016Aspirant
Hi
mdgm-ntgr: I take it the port forwarding would have to be done on the client's router forwarded to the NAS unit's IP and the set the same port in the RNR client software? I have tried that already, but will try again.
JennC: Do you mean disable the firewall/security software & set the DNS on the client's workstation or on the NAS unit / router? I have already tried disabling the firewall on the workstation, it didn't help.
Attached is the leafp2p log (I've just hashed out the IP addresses and usernames)
It looks like it does establish a connection between the client and NAS unit, but then the connection is closed again.
Applying firewall 0 Applying rescan devices 1 url https://peernetwork.netgear.com:443//peernetwork/services/LeafNetsConfigWebService No proxy url https://peernetwork.netgear.com:443//peernetwork/services url https://peernetwork.netgear.com:443//peernetwork/services/LeafNetsWebServiceV2 Config Closed control Closed event control Resolved Host Getting device list Device eth0 0.0.0.2 (null) 192.168.0.### 255.255.255.0 Device any Device lo 0.0.0.1 (null) 127.0.0.1 255.0.0.0 Got device list Opened control Opened control rsockfd 4 Opened event control Opened event control resockfd 5 Opening p2padapter PPAD Listener 0 Returning Opened Adapter ip = 5.15.66.### Login Before accept Starting notifications Get notification Active notification manager Networks 2 Network PYROMED_NAS_204E7FB8D34E's ##### network Member PYROMED_NAS_204E7FB8D34E Member ##### Network PYROMED_NAS_204E7FB8D34E's ##### network Member ##### Member PYROMED_NAS_204E7FB8D34E Service config... Local server.. Started... Login Accepting nsize 0 Accepted connection command 0 type 0 Accepted connection command 2 type 0 Accepted connection command 14 network 8101617 shareType 1 Accepted connection command 14 network 8102045 shareType 1 Accepted connection command 14 network 8101617 shareType 3 Accepted connection command 14 network 8102045 shareType 3 Accepted connection command 15 type 0 connType 2 Getting connect desc ##### 1006936 snid 8101617 NUM ENTERED 1 ##### Cannot post Closed control Getting device list Cannot post Closed event control Opened event control Device eth0 0.0.0.2 (null) 192.168.0.### 255.255.255.0 Device LeafNets 0.0.0.6 (null) 5.15.66.### 255.0.0.0 Device any Device lo 0.0.0.1 (null) 127.0.0.1 255.0.0.0 Got device list Opened event control Opened control Opened control In close p2pconn ##### End close p2pconn ##### Curr time Thu Jan 7 14:00:08 2016 In open p2pconn ##### 0 0 0 0 #####: miaddr 192.168.0.### #####: miport 3613 #####: psockfd = 17 #####: p2p addr 192.168.0.### #####: p2p port 3613 #####: Status 1 #####: setup role 0 #####: ncerr = 1 #####: Status 2 #####: Error Status 51 #####: Error #####: Error code 51 Reverse ##### Closed control In close p2pconn ##### #####: Closing conn Closed conn End close p2pconn ##### NUM LEFT 0 ##### Connection failed -51 Remove CONNECTDESC count 0 Getting connect desc ##### 1006936 snid 8102045 NUM ENTERED 1 ##### Getting device list Device eth0 0.0.0.2 (null) 192.168.0.### 255.255.255.0 Device LeafNets 0.0.0.6 (null) 5.15.66.### 255.0.0.0 Device any Device lo 0.0.0.1 (null) 127.0.0.1 255.0.0.0 Got device list Opened control Opened control In close p2pconn ##### End close p2pconn ##### Curr time Thu Jan 7 14:00:23 2016 In open p2pconn ##### 0 0 0 0 #####: miaddr 192.168.0.### #####: miport 3615 #####: psockfd = 17 #####: p2p addr 192.168.0.### #####: p2p port 3615 #####: Status 1 #####: setup role 0 #####: ncerr = 1 #####: Status 2 #####: Error Status 51 #####: Error #####: Error code 51 Reverse ##### Closed control In close p2pconn ##### #####: Closing conn Closed conn End close p2pconn ##### NUM LEFT 0 ##### Connection failed -51 Remove CONNECTDESC count 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Closed event control Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0 Accepted connection command 13 type 0
Regards
Hi
mdgm-ntgr: I take it the port forwarding would have to be setup on the client's router, with it forwarded to the NAS unit. Then the same ports would have to be specified in the RNR client software? I have already tried port forwarding, but I can try that again.
JennC: Do you mean disable the firewall/security software and set DNS on the workstation or NAS unit? I have already tried disabling the firewall on the workstation without success.
Attached is the leafp2p log (I have hashed out the IP addresses and usernames)
It looks like the NAS unit and RNR client does connect, but then the connection just closes.
Regards
Hi
mdgm-ntgr I take it the port forwarding would have to be setup on the router, with it forwarded to the NAS unit, then the same port would have to be set in the RNR client software?
I have already tried port forwarding, without success, but I can try it again.
JennC Do you mean disable the firewall/security software & set DNS on the workstation or NAS unit? I have already tried disabling the firewall on the workstation, but that did not help.
It looks like the NAS unit and RNR client does establish a connection, but then it just fails and closes.
Regards
