suskis
Mar 04, 2015Aspirant
ReadyNAS Remote
Again, my ReadyNAS 104 is failing in his normal duties.. I wanted to access it using ReadyNAS Remote, as usual, but, suddenly, it disappeared. ReadyNAS Remote client on my pc says my NAS is offline...
Nhellie
Mar 04, 2015Virtuoso
can you try forwarding port 6300 to the LAN IP of your NAS. Then try again, disabling/enabling readycloud and remote. Are you using the ReadyCloud Client app?
