suskis
Mar 04, 2015Aspirant
ReadyNAS Remote
Again, my ReadyNAS 104 is failing in his normal duties.. I wanted to access it using ReadyNAS Remote, as usual, but, suddenly, it disappeared. ReadyNAS Remote client on my pc says my NAS is offline...
RX
Mar 04, 2015Luminary
@suskis:
I assumed that the FW you have on your NAS is v6.2.2. The ReadyCloud Client App replaces the ReadyNAS Remote Desktop Software.
Have you tried to uninstall/reinstall the ReadyCloud Client App or ReadyNAS Remote on your PC?
Try to disable any anti-virus or software firewall running on your PC as well.
