suskis
Mar 04, 2015Aspirant
ReadyNAS Remote
Again, my ReadyNAS 104 is failing in his normal duties.. I wanted to access it using ReadyNAS Remote, as usual, but, suddenly, it disappeared. ReadyNAS Remote client on my pc says my NAS is offline...
Nhellie
Mar 06, 2015Virtuoso
you may have to contact support, I can't think of any more cause of the sudden disconnection from the remote server.
http://support.netgear.com/general/contact/
ReadyCloud and Remote has been "merged", they are using the same connection "leaf" so cloud also uses port 6300. I am not sure why Remote is still on the UI, it might be addressed on future FW updates.
