Leeroy230
Dec 18, 2022Tutor
Readynas RN 102 can't connect to admin page
I've been trying to upgrade drives and haven't been successful but now I can't connect to the NAS with the original drives. I just get "Site can't be reached." Plex is still working and I can acce...
Dec 18, 2022Guru - Experienced User
What status is RAIDar giving you?
Leeroy230
Dec 18, 2022Tutor
Healthy, both drives have a green check mark.
I can ping the IP and I can access the Plex server by adding the extension to the same IP. I can access the Plex files as a network location but my mapped drives don't work.
- StephenBDec 18, 2022Guru - Experienced User
Leeroy230 wrote:
Healthy, both drives have a green check mark.Can you run the diagnostics via RAIDar?
- Leeroy230Dec 18, 2022TutorI can't remember if I tried that. I tried pulling logs but it asked for user name and password and my normal nas user name and password didn't work.
- SandsharkDec 18, 2022Sensei
Are you mapping by IP address or NAS Name? If by name, try via address. Of course, if that fixes it and you've not made the address fixed, you'll want to do that. It's better to do an address reservation in your router than a static IP in the NAS.
I tried mapping IP and name and nothing works. The one folder I have mapped via name doesn't work any longer. Windows did find it as a network device and I can access the Plex folders only. I can ping the IP and ReadyCloud finds the correct IP as well.
