apopcontest
Jan 13, 2024Aspirant
ReadyNas RN2100 hacked
So it appears that my credentials were exposed after a recent data breach from Netgear (thanks guys) and I received an email a few months back saying all my data and been stolen and I wanted to get i...
Jan 14, 2024Guru - Experienced User
I'm puzzled here. Can you confirm that the NAS is an RN2100 running 4.1.x firmware? Did you get an email from Netgear telling you there was a breach? Or are you just speculating?
The Netgear cloud services that can reach your NAS over the internet (photos and readyremote) were taken down long ago. There is no Netgear cloud account or server that is linked to your NAS.
How were the hackers able to reach your NAS? Were you forwarding ports to it?
- apopcontestJan 15, 2024Aspirant
Hello,
Currently away from where my NAS is located for a few days, I can confirm that my NAS is RN2100 running 4.1.x firmware and I do recall reading an email from Netgear informing me of a data breach, however I have had a few to be honest and I never really paid attention to them too much.
I was under the impression that ReadyNAS Cloud was only closed late last year (which I was unaware of) and I have ReadyCloud Client installed on my computer which I cannot access which I understand.
I am not sure how the hackers were able to access my NAS, I can access it using what I created at the time for my username and password which was email and an old password which I never changed, I believe this password is probably available somewhere online for people to make attempts to login using my credentials,Would this be how they were able to access my NAS?
Any recommendations on how to move forward? Do a hard reset? My concern would be that if I placed data on my NAS, a hacker would be able to access my NAS using my old credentials.
- StephenBJan 16, 2024Guru - Experienced User
Netgear branding has often re-used old names, which unfortunately creates a lot of confusion. The ReadyCloud you had installed was shut down in September 2016, so your NAS hasn't been connected to it for 7 years.
The service that was shut down in July was only for ReadyNAS running 6.x firmware. So not compatible with your NAS.
Let's start from the beginning. FWIW, I don't think your NAS ever supported email format usernames, so that part of your email is a bit confusing.
What apps did you have installed on your NAS? Bittorrent perhaps?
Did you ever forward any ports in your router to the NAS?
You received an email from someone claiming to have encrypted your files. Did they specifically say they had hacked your ReadyNAS? Or just that they had encrypted files? Did you click on any links or open any attachments in that email? It's possible that the email was fake.
You are away from home, and cannot access your NAS. Have you tried accessing it while you were home? When did you lose access?
If you have access, are you able to see your shares? If so, what files are you seeing in the shares?
When you try to access frontview now (when home) are you getting an SSL version or Cipher Mismatch error? Or are you getting something else.
Not unless you had forwarded ports to the NAS to enable remote connections. Or alternatively if they compromised a PC you use to connect to the internet.
FWIW, I am not (yet) seeing strong evidence that the NAS was in fact hacked. There were changes in Chrome, Edge, Firefox, and Safari last year that do prevent access to Frontview. There are some workarounds, but AFAICT you don't know about them.
It is also possible that disk failures (or a NAS failure) is the actual cause of your problem. So there are other explanations to lack of access that haven't really been ruled out.
Do you only have an access problem reaching your files? Or do you actually see encrypted files on the NAS when you access it.
As far as old credentials go, if you do a factory default then those credentials will no longer work with the NAS. But of course if you also use them for other devices (or accounts) you should start by changing them.
Plus access to your NAS over the internet requires more than the old credentials. Normally your router won't allow a hacker to reach the NAS. So we'd also need to understand how the alleged hacker managed to get through your router.
- apopcontestJan 18, 2024Aspirant
Sorry I don't know how to quote, so I will try and answer accordingly...
Not Bittorrent, I only had Plex Server installed on NAS, could they have gained access with a compromised username and password on Plex?
Please see this screenshot, the same message was saved on my NAS which was emailed, which I initially ignored as I was busy at the time. I have blocked out other information for the safety of others.
Is there a way to find this?
Here are some other screenshots for further assistance.
Moving forward, should I remove the Plex App? Hard to tell if my computer was compromised I do have paid antivirus protection on my laptop. I have been exposed to a few data breaches already but nothing too major (so far), I thought perhaps my older credentials have been sitting somewhere on the internet and someone had a crack at accessing my NAS through ReadyCloud. The only way I can access the NAS currently is by clicking on the explorer button and selecting 'Network' then when accessing the drive, I am asked to login, which I used my ReadyCloud email address and password, this is what gives me the understanding that a hacker was able to access my files using these credentials.
How do you suggest I proceed moving forward to secure the device?
