cjborntorun
Nov 18, 2019Aspirant
ReadyNAS RN212 went offline
I've disconnected power from the ReadyNAS for as much as 10 minutes. Turned it back on. No luck. I've been trying to troubleshoot if I might need a firmware update, but how do I do that, if its is of...
cjborntorun
The Windows 10 update happened a week or so ago--that's what happened. I continue to be able to access the ReadyNAS through by LAN when I'm connected at my office, but NOT ReadyCloud.
cjborntorun
Also, you mentioned storage used. No way it's full. I have 2 - 2TB drives and just started using this last June. My last update on the Insight App indicates Storage Use: 229.78GB of 1.81TB
