rf19
Mar 03, 2019Aspirant
ReadyNAS102 - Readycloud partial share failure
Up to end of 2018 I had used Readycloud to give family members access to the Pictures share on my RN102 (I've used both password protected links, and inviting via email [which prompts them to create ...
- Mar 06, 2019
Try going into the NAS admin web ui. Select the settings wheel for the Picture share, and then select the "file access" tab.
You'll see a "reset" control on the right of the page. Click on that, and then click on "reset permissions".
Marc_V
Mar 04, 2019NETGEAR Employee Retired
Hi rf19
Welcome to the Community!
Have you updated your firmware? you may want to check and see if a NAS reboot could help. Checking the NIC settings for DNS servers might help as well.
Hope this helps!
Regards
rf19
Mar 04, 2019Aspirant
Hi Marc_V, yes I'm running 6.9.5 and in fact had updated not long before the issue became apparent (although not clear it was directly related). Not sure how I would check those settings, or what I would be looking for (what may be set incorrectly).
Thanks for your help
- StephenBMar 04, 2019Guru - Experienced User
Is your NAS set up to use the default DHCP (automatic IP address assignment), or did you change that to use a static IP address?
- rf19Mar 04, 2019AspirantIt's on a fixed IP. Same one for more than a year.
