rf19
Mar 03, 2019Aspirant
ReadyNAS102 - Readycloud partial share failure
Up to end of 2018 I had used Readycloud to give family members access to the Pictures share on my RN102 (I've used both password protected links, and inviting via email [which prompts them to create ...
- Mar 06, 2019
Try going into the NAS admin web ui. Select the settings wheel for the Picture share, and then select the "file access" tab.
You'll see a "reset" control on the right of the page. Click on that, and then click on "reset permissions".
rf19
Mar 06, 2019Aspirant
Just to clarify, the settings I'm referring to are specifically in the folder Properties box, under the Security tab; under Group/Usernames, I see in some folders that my external user's username is present (for those folders he happens to have access to). For other folders their username is not in the list. This is all despite me sharing the shared Pictures folder at the top level via ReadyCloud.
Mar 06, 2019Guru - Experienced User
- rf19Mar 06, 2019Aspirant
Thanks StephenB - that seems to have done the trick!
