portiah
Aug 28, 2017Aspirant
Remote Access Readynas RND2000 duo V2
As you can see I have a Nas drive which is a few years old. I have never used it remotely but I would like to now. Am i right in thinking that the Readynas remote app has been replaced by ReadyCLOU...
JennC
Sep 01, 2017NETGEAR Employee Retired
Hello portiah,
It should not be set to the IP address of the NAS. When the IP address of the NAS is set to Obtain IP address automatically, the DNS will be obtained automatically too but if you set a static or manual IP address to the NAS then you would have to set a manual DNS too.
Try changing the DNS1 to the network router's IP address and DNS2 to 8.8.8.8.
portiah
Sep 01, 2017Aspirant
Sorry my mistake - DNS1 is set to the IP address of the router. I was looking at the Ethernet address. I have done exactly as you say - Configure and click the DNS settings icon but it will not let me edit the DNS settings.
Thank you very much for your help.
