portiah
Aug 28, 2017Aspirant
Remote Access Readynas RND2000 duo V2
As you can see I have a Nas drive which is a few years old. I have never used it remotely but I would like to now. Am i right in thinking that the Readynas remote app has been replaced by ReadyCLOU...
Martyblyth
Sep 06, 2017Aspirant
Hi there,
Im getting all the same problems, and im on the virgin meida superhub as well, On the plus side i did find a way to change my DNS settings on the overview page of the ReadyNAS chaing it to what you recommend but still no luck.
Any updates would be helpful
Thanks Marty.
portiah
Sep 07, 2017Aspirant
Thanks for the info. I still can't edit the dns on the readynas dashboard. It just won't let me change anything on the dns popup window.
