steveTu
Jan 22, 2021Apprentice
Resend Readycloud Share Invites
ReadyNAS 212 - OS 6.10.4 Is there a way to resend Readycloud share invites? I set up a couple of EMails ages back to access certain shares and they were never accessed. How can I resend the invit...
- Jan 22, 2021
Hi steveTu,
You can re-invite the ReadyCLOUD users by removing them first from the invited users, then send again an email invite to the user.
To remove a ReadyCLOUD user, you may just log in to my.netgear.com, then select the share you want to manage. You can then just click the 'x' button next to the invited user to remove that user.
You may also check this article for reference.
JohnCM_S
Jan 22, 2021NETGEAR Employee Retired
Hi steveTu,
steveTu
Jan 23, 2021Apprentice
Thanks John - that was the only way I could see of doing it - it just seemed a bit like overkill. But if that's the way, fine.
Thanks again.
