montybiggleswor's avatar
Apr 23, 2020
RN10200 Not powering up - only sign of life is the Ethernet port LED flashes - is it dead?
I noticed today that the LED was off on our RN10200, I tried to power it back on but nothing happes.  No lights, no fans, no noise, nothing! I tested the PSU and that's still outputting 12v.  We u...
  • Sandshark's avatar
    Sandshark
    Apr 23, 2020
    Yes, the NIC and power-on circuit draw power even when the NAS is "off".  The +12V is internally dropped down to the necessary voltages, including the standby voltage those items use.  From your list of symptoms and tests run, I think it most likely something in that power circuit is the problem.  Big caps would be a place to start.
    Unfortunately, Netgear does not make schematics available, so troubleshooting is an adventure.  Good luck.
ProSupport for Business
