Bigmaca
Jul 12, 2022Aspirant
RN214 Shows All Volumes As Red
Hi, My ReadyNAS 214 recently powered off and after turning it back on it now shows the three volumes that I have in the colour Red. The markers are green which makes me assume they are fine but ...
- Aug 21, 2022
This has now been resolved.
After having no help with Netgear Customer service, StephenB was able to offer fantastic assistance. I ended up needing to force a resit of the drives through a telnet terminal. There was then a need to delete chunk stream files that had been left over from Plex that where on the admin page.
Thanks again StephenB.
Jul 12, 2022Guru - Experienced User
Bigmaca wrote:My ReadyNAS 214 recently powered off and after turning it back on it now shows the three volumes that I have in the colour Red.
Be careful on the vocabulary. You have one data volume (currently inactive), and three disks. The three disks are red because they are not part of an active data volume.
Was the shutdown graceful, or was there a sudden loss or removal of power? I am thinking it might be the latter. That can create an out of sync volume, due to cached writes that were lost when the power failed.
I'd start with Netgear support (support.netgear.com), and see if you can get paid support from them.
Bigmaca
Hi StephenB,
Thank you for the help here and sorry for the use of the wrong vocabulary. Still trying to get my head round it. I believe there was a sudden abrupt loss of power but I can't be sure. I'll look at using the support you mentioned.
