craigat
Sep 10, 2024Aspirant
ReadyNAS RN316 showing Volume Is read-only
Can someone please help.
My RN316 is showing "Volume is read-only".
i've tried replacing 3 of the 6 disks, only 1 of which had shown any errors in the "ATA error" item when you hover the mouse over it in the web interface. Its getting to expensive to just replace disks for the "heck of it".
If I copy all the data off, what do I do to resolve this?
THANKYOU!
craigat wrote:
Hi,
The RN316 seems fine... its just read-only.. I can copy files off it, I can play videos from it.
Is there anything I can do? or just destroy it?
Thanks,
Craig
The best strategy is to do a factory reset, set up the NAS again, and restore the data from a backup.
Which is why I keep asking if you've made a backup.
Read-only is usually triggered by a problem with the BTRFS file system, not the disk drives.
You could try downloading the full log zip file from the NAS, and looking in there for details. There is a lot of info there, I could help you analyze it if you like. (Don't post a link to the logs publicly, as there is some information leakage when you do that).
Do a factory default (either from the boot menu or system->settings->update in the admin web ui). Then reconfigure the NAS (recreating shares, etc) and copy the data back.
- SandsharkSensei
What you have been doing is may create more issues, it won't solve the problem. The volume has gone read-only to prevent you from doing further damage before you back up the files, so take the hint.
You should be able to save the configuration and restore it again later rather than completely re-configure manually. Note that you do need to use the same volume name for that to work. You likely can also just destroy and re-create the data volume.
If your NAS set-up is pretty standard without a lot of users, it won't matter much. Note that you will need to restore apps in either case, which now takes extra effort.
- craigatAspirant
Hi
Thanks guys for the reply.
10+ yrs ago I spent time in the u*ix/l*ix space but dont know brfs at all. I did download the logs & in dmesg.log I see:
NTFSJ support included
Hfs+J support included
Build_for__Netgear_RN314_x86_64_k4.1.16_2016-04-19_lke_9.6.4_b635
[Wed Sep 11 17:18:28 2024] ufsd: PAGE_SIZE=4K, THREAD_SIZE=16k
[Wed Sep 11 17:18:28 2024] ufsd: Can't open /proc/config.gz
[Wed Sep 11 17:18:28 2024] ufsd: Kernel .config hash: original unknown, current can't check.
[Wed Sep 11 17:18:31 2024] ufsd: "mount" (sdh2): is mounted as NTFS(rw) at 2024-09-11 07:18:31
[Wed Sep 11 17:18:32 2024] nfsd: last server has exited, flushing export cache
[Wed Sep 11 17:18:32 2024] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[Wed Sep 11 17:18:32 2024] NFSD: starting 90-second grace period (net ffffffff88d782c0)
[Wed Sep 11 17:18:37 2024] nfsd: last server has exited, flushing export cache
[Wed Sep 11 17:18:37 2024] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[Wed Sep 11 17:18:37 2024] NFSD: starting 90-second grace period (net ffffffff88d782c0)
[Wed Sep 11 17:30:57 2024] BTRFS error (device md127): bdev /dev/md127 errs: wr 1, rd 0, flush 0, corrupt 0, gen 0
[Wed Sep 11 17:30:57 2024] BTRFS error (device md127): bdev /dev/md127 errs: wr 2, rd 0, flush 0, corrupt 0, gen 0
[Wed Sep 11 17:30:57 2024] BTRFS error (device md127): bdev /dev/md127 errs: wr 3, rd 0, flush 0, corrupt 0, gen 0
[Wed Sep 11 17:30:57 2024] BTRFS error (device md127): bdev /dev/md127 errs: wr 4, rd 0, flush 0, corrupt 0, gen 0
[Wed Sep 11 17:30:57 2024] BTRFS error (device md127): bdev /dev/md127 errs: wr 5, rd 0, flush 0, corrupt 0, gen 0
[Wed Sep 11 17:30:57 2024] BTRFS: error (device md127) in btrfs_commit_transaction:2249: errno=-5 IO failure (Error while writing out transaction)
[Wed Sep 11 17:30:57 2024] BTRFS info (device md127): forced readonly
[Wed Sep 11 17:30:57 2024] BTRFS warning (device md127): Skipping commit of aborted transaction.
[Wed Sep 11 17:30:57 2024] BTRFS: error (device md127) in cleanup_transaction:1864: errno=-5 IO failure
[Wed Sep 11 17:30:57 2024] BTRFS info (device md127): delayed_refs has NO entry
[Thu Sep 12 08:55:14 2024] md: md127: recovery done.
[Thu Sep 12 08:55:17 2024] RAID conf printout:
[Thu Sep 12 08:55:17 2024] --- level:5 rd:6 wd:6
[Thu Sep 12 08:55:17 2024] disk 0, o:1, dev:sda3
[Thu Sep 12 08:55:17 2024] disk 1, o:1, dev:sdb3
[Thu Sep 12 08:55:17 2024] disk 2, o:1, dev:sdc3
[Thu Sep 12 08:55:17 2024] disk 3, o:1, dev:sdd3
[Thu Sep 12 08:55:17 2024] disk 4, o:1, dev:sde3
[Thu Sep 12 08:55:17 2024] disk 5, o:1, dev:sdf3
[Thu Sep 12 09:36:30 2024] BTRFS error (device md127): Remounting read-write after error is not allowed
[Thu Sep 12 09:36:53 2024] BTRFS error (device md127): Remounting read-write after error is not allowed
[Thu Sep 12 10:16:39 2024] BTRFS error (device md127): Remounting read-write after error is not allowed
[Thu Sep 12 17:36:38 2024] BTRFS error (device md127): Remounting read-write after error is not allowedTrusting the RAID5 too much, I did think replacing the erroring disk (4 ATA erros, but not enough for the RN316 to change it to status RED) would help, but clearly not.
[Wed Sep 11 17:30:57 2024] BTRFS: error (device md127) in btrfs_commit_transaction:2249: errno=-5 IO failure (Error while writing out transaction)5 writes to the volume failed. Can you check other logs (system.log, kernel.log, systemd-journal.log) for errors at this time?
Since you do have read access, you should
- immediately back up the files to other storage
- do NOT reboot the NAS, as that might result in losing access altogether.
