Bigmaca
Jul 12, 2022Aspirant
RN214 Shows All Volumes As Red
Hi, My ReadyNAS 214 recently powered off and after turning it back on it now shows the three volumes that I have in the colour Red. The markers are green which makes me assume they are fine but ...
- Aug 21, 2022
This has now been resolved.
After having no help with Netgear Customer service, StephenB was able to offer fantastic assistance. I ended up needing to force a resit of the drives through a telnet terminal. There was then a need to delete chunk stream files that had been left over from Plex that where on the admin page.
Thanks again StephenB.
Bigmaca
Hi StephenB,
Would a possible reinstall of the OS fix this issue?
I'm also not sure on what level of support to purchase with Netgear, it's not very clear.
Jul 12, 2022Guru - Experienced User
No, that won't help at all.
There are a few possibilities -
- the RAID array might be too far out of sync to mount manually. It can be "forcibly" assembled,
- the RAID array might be ok, but there might be some BTRFS file system corruption which is blocking the mount.
If (2) the corruption might be repairable with normal BTRFS tools. Or actual data recovery might be needed.
Based on what we know at this point, I think there's a good chance of avoiding full data recovery.
- BigmacaJul 13, 2022Aspirant
Thank you Stephen.
I've just created a case and am waiting for Netgear to get back to me. I've tried contacting premium support but they said I need to have a case number first.I'm worried they won't be able to offer support for the device. If that's the case do I have any other options to get my data off the drives? I'm assuming that doing a manually mount or BTRFS file corruption is something that I can sort myself.
Really appreciate your help and guidance on this. If I manage to get this working I might need to look at upgrading the NAS unit and backing it up.
- StephenBJul 13, 2022Guru - Experienced User
Putting a backup plan in place should be the first priority, though you could accomplish both by gettting a new NAS and backing up to this one.
There are some things you could do on your own. How much experience do you have with the linux command line (ssh)?
StephenB wrote:
Bigmaca wrote:If I manage to get this working I might need to look at upgrading the NAS unit and backing it up.
Bigmaca wrote:I'm worried they won't be able to offer support for the device. If that's the case do I have any other options to get my data off the drives? I'm assuming that doing a manually mount or BTRFS file corruption is something that I can sort myself.
Agreed - if I was to purchase a new ReadyNAS system, could I just attached the drives (in the same order) and everything possibly be ok?
I have minimal to next to no experience in linux command line (ssh). If you're able to point me towards materials and guides I'd be happy to look.
I am now in contact with support so fingers crossed they might be able to give assistance
