Mitsai
Jul 24, 2016Tutor
RN316 - Downloaded file is very small size after updated 6.5.1
Hi all, No one same situation after updated 6.5.1??? I could not download my files properly when I upgraded ReadyOS from 6.5.0 to 6.5.1. Before installed 6.5.1, I have no issues, conditions are gr...
JennC
Jul 26, 2016NETGEAR Employee Retired
Hello Mitsai,
How to do you check the files size? These files that you claim small size compared to its size before updating to 6.5.1, are you able to open them?
I noticed you are from Japan, would you like me to move your post to Japan board?
Welcome to the community!
- MitsaiJul 26, 2016Tutor
Hi JennC,
Thank you for your response on my issue.
It is fine if somebody can response in Japan board.
Unfortunately I have never seen that solved similar problem in the past Japan board since lack of technical? I have no idea, therefore I asked here because a lot of professional responded. However, I understand you said we have region issue? may be. Anyway, Thanks for your advises.
Best regards,
In addition,
I would like to reply on your question, please note.
1. How to do you check the files size? -> by explorer property
2. These files that you claim small size compared to its size before updating to 6.5.1, are you able to open them? -> before updated 6.5.1, could be opened. after updated, could not open, windows attention error broken file.
- JennCJul 27, 2016NETGEAR Employee Retired
Hello Mitsai,
Is this from just one share? Can you manually copy a file to this share and see if you get the same results?
Do you have full backup of the files?
