Mitsai
Jul 24, 2016Tutor
RN316 - Downloaded file is very small size after updated 6.5.1
Hi all, No one same situation after updated 6.5.1??? I could not download my files properly when I upgraded ReadyOS from 6.5.0 to 6.5.1. Before installed 6.5.1, I have no issues, conditions are gr...
GPSIS_HQ
Jul 27, 2016Guide
Hello all,
I had the same issue...small sized files post download, but on my RN204 they were correct size and opened properly.
Everything worked great until v6.5.1 came along then the previously lallowed links to files only downloaded 200-400 kb file sizes.
The associated application icon would show up, but the file would cause an error when trying to open; basically stating the file was not a avalid <associated aplication> file.
Once I reverted back to v6.5.0 my problem was resolved.
BrianL2
Jul 27, 2016NETGEAR Employee Retired
Hi GPSIS_HQ & Mitsai,
This problem you raised might be related to this thread. Were these files downloaded via web link? or was it downloaded using the web portal or the mobile/desktop apps?
Kind regards,
BrianL
NETGEAR Community Team
- GPSIS_HQJul 27, 2016Guide
I created and emailed a web link via ReadyCloud portal.
However [if this helps] I could use ReadyCloud on my laptop from work or home and open the files that had problems in the web links.
I had no problem with the mobile app accessing my files.
Regards!
- MitsaiJul 28, 2016Tutor
Thanks JennC, GPSIS_HQ, BrianL,
I understand that some users has faced similar trouble and it is still not solved,,,,,,,,,
- BrianL2Jul 28, 2016NETGEAR Employee Retired
I couldn't think of any solution at this point. It would be better if you will raise this issue to our support team and have it escalated to our tier 3 support.
Kind regards,
BrianL
