Mitsai
Jul 24, 2016Tutor
RN316 - Downloaded file is very small size after updated 6.5.1
Hi all, No one same situation after updated 6.5.1??? I could not download my files properly when I upgraded ReadyOS from 6.5.0 to 6.5.1. Before installed 6.5.1, I have no issues, conditions are gr...
BrianL2
Jul 27, 2016NETGEAR Employee Retired
Hi GPSIS_HQ & Mitsai,
This problem you raised might be related to this thread. Were these files downloaded via web link? or was it downloaded using the web portal or the mobile/desktop apps?
Kind regards,
BrianL
NETGEAR Community Team
GPSIS_HQ
Jul 27, 2016Guide
I created and emailed a web link via ReadyCloud portal.
However [if this helps] I could use ReadyCloud on my laptop from work or home and open the files that had problems in the web links.
I had no problem with the mobile app accessing my files.
Regards!
- MitsaiJul 28, 2016Tutor
Thanks JennC, GPSIS_HQ, BrianL,
I understand that some users has faced similar trouble and it is still not solved,,,,,,,,,
- BrianL2Jul 28, 2016NETGEAR Employee Retired
I couldn't think of any solution at this point. It would be better if you will raise this issue to our support team and have it escalated to our tier 3 support.
Kind regards,
BrianL
