IH784
Aug 18, 2023Aspirant
Running ZeroTier on RAX29
Is there any way to run ZeroTier on an RAX29 nighthawk router? Do I use Readyshare?
Sandshark
Aug 18, 2023Sensei
You have posted in the ReadyNAS area. You'll likely get a better response in the proper forum.
That said, I don't believe ZT can be installed with Netgear firmware. But if your router can run OpenWRT or another open source firmware, it can, See https://zerotier.atlassian.net/wiki/spaces/SD/pages/743866369/Router+Firmwares .
IH784
- FURRYe38Aug 18, 2023Guru - Experienced User
- IH784Aug 18, 2023AspirantThank you. That was very helpful. Lmao.
- michaelkenwardAug 18, 2023Guru - Experienced User
IH784 wrote:
Thank you. That was very helpful. Lmao.When someone turns up here with some odd device or system, it can help to see if anyone has already thrown the same challenge into the mix. If nothing else, it shows how many people are in the same boat.
Sadly, you seem to be among a small and elite bunch of people with even a vague clue as to what ZeroTier might be.
Search - NETGEAR Communities – ZeroTier
That is one of the shortest hit list that I have seen.
