NASty1
May 19, 2016Aspirant
Setting up a used readynas to use with my netgear account
I recently purchased the 31400 through e-bay auctions. When I try and use it through readycloud, it says " it finds no registered devices or shares." When I tried to register it, netgear informs me...
- May 25, 2016
I don't know how it happened, but my ypgrade to OS 6.5 was incomplete. A day later I attempted the setup and it worked! Thanks for the suggestion. I'll probably never figure out how you get a partial install, but apparently that was the problem. THANKS !!!?
NASty1
May 25, 2016Aspirant
JennC
Aug 16, 2016NETGEAR Employee Retired
Hello NASty1,
I am glad it works now.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
Please feel free to post any suggestions, comments or questions, we appreciate your contribution to the community!
