zhenya
Sep 15, 2020Aspirant
Unable to get ReadyNAS with Dropbox going
I am trying to setup my ReadyNAS to sync with Dropbox. It goes fine through first few screen, connects to Dropbox, but this is where it ends. I am prompted with Dropbox - Session window. When Cl...
Marc_V
Sep 15, 2020NETGEAR Employee Retired
Have you checked if you have any firewall on your PC that can limit the access? Or any security software you may have.
You can try to use another browser or PC and retry creating a Dropbox sync. Adding DNS server addresses on your NAS NIC might help as well.
HTH
- leecroninOct 06, 2020Aspirant
I'm having the same problem. It is serious. Dropbox USED to work and then suddenly my account stoped. I checked with another dropbox to my readynas and that is ok. I cannot work out what is wrong with my dropbox that is preventing the root directory to be listed. This is seriously messing up my workflow.
I need help.
Thanks.
Lee
- WilfredReurinkNov 24, 2020Aspirant
I experience exactly the same problem since a week or so. It used to work perfectly.
Please help.
