uffgnu14
Jan 24, 2016Luminary
Unknown units, can not connect
ReadyNAS Ultra2 Plus RN OS 6.4.2-RC1 ReadyCLOUD 1.2.2 for Android 5.0 Hi Can't connect to ReadyCLOUD share anymore, was working fine on Friday 22 January. When signed in I see 3 units of wh...
- Feb 21, 2016Hi
My ReadyCLOUD-problem solved, I hope. I don't exactly know how it got fixed or
what caused the problem in first place but now all ReadyCLOUD access methods are
working and the previous missing Home shares are available.What I did was experimenting with combinations of Signing In/Out, removal of "Unknown" devices,
RN On/Off.One thing I noticed at times was that if a Home share is empty it was not visible.
Ulf
uffgnu14
Hi
"mdgm", logs sent.
Ulf
mdgm-ntgr
Jan 25, 2016NETGEAR Employee Retired
I did not receive the logs.
- uffgnu14Jan 25, 2016Luminary
Hi "mdgm"
Logs sent according to "Sending logs" link in your signature.
Ulf
- mdgm-ntgrJan 25, 2016NETGEAR Employee Retired
It turns out that I needed to restart the email software I was using and then I got your email.
Not sure what is causing this.
I see you don't have much data on your system. Could you try backing up that data, doing a factory default (wipes all data, settings, everything) and restoring your data from backup?
