Ag99JYD
Jan 01, 2022Follower
WD MyCloud on ReadyCloud
Has anyone been able to mount a WD MyCloud to ReadyCloud? Remote access and USB Content Availaiblity are enabled on the admin page of the device. It is an older model that can be accessed via the W...
Jan 02, 2022Guru - Experienced User
I don't think that is possible. MyCloud is a NAS (providing ethernet-connected storage). You can't access the files over USB. What you need for this is a USB hardrive, not a NAS.
But you shouldn't need to combine ReadyCloud with MyCloud. WD has their own solution for remote access built into MyCloud. ( https://www.mycloud.com/#/ >
