Dimitri_P
Sep 28, 2011Aspirant
4.2.20 [T4] ~ Cacti addon kills https/frontview
Everything worked fine, until I installed Cacti addon and rebooted. Now Frontview won't work. Any suggestions what should be done? I wanted to install/uninstall Cacti addon - so it takes the ...
mdgm-ntgr
Dec 22, 2011NETGEAR Employee Retired
For future reference, if you install EnableRootSSH then if you have a problem where an add-on breaks Frontview you can SSH in and fix it. Of course EnableRootSSH has to be installed before the problem emerges.
