Dimitri_P
Sep 28, 2011Aspirant
4.2.20 [T4] ~ Cacti addon kills https/frontview
Everything worked fine, until I installed Cacti addon and rebooted. Now Frontview won't work. Any suggestions what should be done? I wanted to install/uninstall Cacti addon - so it takes the ...
skaarji
Dec 28, 2011Aspirant
ReadyNAS:/# cat /var/log/raidiator_version
RAIDiator!!version=4.2.20-T19,time=1322851404
the error log says:
apache-ssl: Syntax error on line 344 of /etc/frontview/apache/httpd.conf: Syntax error on line 1 of /etc/frontview/apache/addons/PHP5.conf: Cannot load /usr/lib/apache2/modules/libphp5.so into server: /usr/lib/apache2/modules/libphp5.so: cannot open shared object file: No such file or directory
[Wed Dec 28 08:42:51 2011] [error] [client 192.168.59.201] File does not exist: /frontview/ui/resource/html/CACTI, referer: https://readynas/admin/
[Wed Dec 28 08:43:00 2011] [error] [client 192.168.59.201] File does not exist: /frontview/ui/resource/html/CACTI, referer: https://readynas/admin/
the error log says:
