Dimitri_P
Sep 28, 2011Aspirant
4.2.20 [T4] ~ Cacti addon kills https/frontview
Everything worked fine, until I installed Cacti addon and rebooted. Now Frontview won't work. Any suggestions what should be done? I wanted to install/uninstall Cacti addon - so it takes the ...
mdgm-ntgr
Dec 28, 2011NETGEAR Employee Retired
If you remove the add-on it should remove that PHP5.conf file.
Alternatively you could rename the PHP5.conf file e.g. to PHP5.conf.old and then try restarting Frontview.
