Dimitri_P
Sep 28, 2011Aspirant
4.2.20 [T4] ~ Cacti addon kills https/frontview
Everything worked fine, until I installed Cacti addon and rebooted. Now Frontview won't work. Any suggestions what should be done? I wanted to install/uninstall Cacti addon - so it takes the ...
AMRivlin
Feb 17, 2012Apprentice
I am running 4.2.19, but I have the same issue as above.
SO I just fell into the Cacti Trap. (Fortunately I have SSH running) but I am stuck. I ran
I then
Did I do this correctly? Is my PHP now dead? Can I reinstall it?
Please delete the cacti add on from the ReadyNAS website so this doesn't happen to another.
sh cacti.remove, but now what?
apache-ssl: Syntax error on line 343 of /etc/frontview/apache/httpd.conf: Syntax error on line 1 of /etc/frontview/apache/addons/00_php5module.conf: Cannot load /usr/lib/apache2/modules/libphp5.so into server: /usr/lib/apache2/modules/libphp5.so: cannot open shared object file: No such file or directory
I then
mv /etc/frontview/apache/addons/00_php5module.confand PHP5.conf
