Digital999
Jan 13, 2023Luminary
626
Removed two disks from an older system and installed in the ReadyNAS system. INstalled into existing system and get an error message. What do I do to get the system to recognize these driv...
- Jan 14, 2023
Digital999 wrote:
Yes, we want tow different volumes of different sizes. Lots of history there but that is what we want.
Have you switched to flexraid? If you haven't, then that is the first step. If you see a green stripe on the XRAID control, then click on it. (the green stripe signifies XRAID is on).
Then you'd select the two disks and create a new volume on them.
Not sure what is going on with disk 4. It kind of looks like you'd already created a volume, but and not just formatted the drives??? If that is the case, you'd need to click on the volume settings wheel for bank-3 and bank-4, and delete those volumes (before you can create a new RAID-1 volume).
Digital999
Jan 14, 2023Luminary
Thank you for your reply -- much appreciated.
Moving disks to a PC environment and back after reformatting is way past what our field folks could handle successfully.
Instead I powered down, removed the drives, powered up and inserted them one at a time and formatted each drive with the ReadyNAS software.
Then I fiddled -- now each drive is recognized and one of them is characterized as a new volume -- Bank 2.
As you can see the two drives are 'sort of' recognized. One is a JBOD and the other is ??
Any suggestions on how to move forward to make them (3 and 4 from the top) into a RAID 1 volume?
Jan 14, 2023Guru - Experienced User
- Digital999Jan 14, 2023Luminary
The actual reply did not seem to post. Post again please.
- StephenBJan 14, 2023Guru - Experienced User
Try refreshing and see if it shows up. Your reply was within a minute of mine.
But here it is again.
Is that what you want? Personally I'd stick with XRAID, which would give me a single 22 TB volume.
If you make 3+4 RAID 1, then you'd have a 12 TB volume plus a 6 TB volume - so 4 TB less space overall.
