ygator
Feb 10, 2013Aspirant
AddOn not working and cannot be removed
ReadyNAS Duo V2 I followed the instructions for creating an addon from http://www.readynas.com/?p=346. I was able to install the addon. However, when trying to run it by clicking on save a spin...
ygator
Feb 13, 2013Aspirant
I did it from a different Linux system which the link I posted said you could do. After I installed SSH I went ahead and did it from the readynas with the same results.
I believe something is broke because when I look at /var/log/frontview/error.log I see the following errors:
ReadyNAS Started Up
[Wed Feb 13 18:18:51 2013] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
Browsing to https://readnas/
[Wed Feb 13 18:19:09 2013] [error] [client 10.x.x.x] File does not exist: /frontview/dashboard/images/scroller/style1-lr.png, referer: https://readynas/admin/
[Wed Feb 13 18:19:09 2013] [error] [client 10.x.x.x] File does not exist: /frontview/dashboard/images/scroller/style1-tb.png, referer: https://readynas/admin/
Clicking Configure
[Wed Feb 13 18:20:57 2013] [error] [client 10.x.x.x] File does not exist: /frontview/dashboard/images/scroller/style1-tb.png, referer: https://readynas/admin/index.html
[Wed Feb 13 18:20:58 2013] [error] [client 10.x.x.x] File does not exist: /frontview/dashboard/images/scroller/style1-lr.png, referer: https://readynas/admin/index.html
Install AddOn
No Errors Output
Clicking AddOn
[Wed Feb 13 18:22:58 2013] [error] [client 10.x.x.x] File does not exist: /frontview/ui/resource/html/COOLADDON, referer: https://readynas/installed/installed.html?addon=COOLADDON&locale=en-us
Checking box putting in time and clicking Save
[Wed Feb 13 18:24:16 2013] [error] [client 10.x.x.x] File does not exist: /frontview/ui/resource/html/COOLADDON, referer: https://readynas/installed/installed.html?addon=COOLADDON&locale=en-us
Clicking Remove
[Wed Feb 13 18:25:27 2013] [error] [client 10.x.x.x] File does not exist: /frontview/ui/resource/html/COOLADDON, referer: https://readynas/installed/installed.html?addon=COOLADDON&locale=en-us
[Wed Feb 13 18:25:28 2013] [error] [client 10.x.x.x] File does not exist: /frontview/ui/resource/html/COOLADDON, referer: https://readynas/installed/installed.html?addon=COOLADDON&locale=en-us
ReadyNAS Started Up
Clicking Configure
Install AddOn
No Errors Output
Clicking AddOn
Clicking Remove
