mlock's avatar
mlock
Guide
Oct 16, 2018
CBR40 - remove satellite?
How do you disconnect a satellite from the CBR40?  RBS50Y outdoor satellite is not working on my system (maybe not even compatible ... different thread discussion).  For now just want to remove it from the system as an attached device.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    mlock
    RBS50Y (Orbi Outdoor Satellite) should work with any existing Orbi setup except Orbi Pro. I have sent you a message. Please check your inbox.
    Blanca
    Community Team
  • FURRYe38's avatar
    Should be able to remove it from the routers UI, or just power OFF the RBSY.
    • mlock's avatar
      mlock
      Guide
      If it can be done from the User Interface - I haven't found it yet. Unplugged both of the RBS50Ys couple days ago, but they still show up as "Connected Satellites" under "Attached Devices".
      • FURRYe38's avatar
        Even after rebooting the router?
