ygator's avatar
ygator
AddOn not working and cannot be removed
ReadyNAS Duo V2
I followed the instructions for creating an addon from http://www.readynas.com/?p=346.
I was able to install the addon. However, when trying to run it by clicking on save a spinner pops up and spins forever. Same goes for trying the remove button.
How can I remove this addon and how do you create an addon for the Duo V2?
Thanks,
YGator
  • As for the error for the addon
    All the addon files are located under /etc/frontview/addons NOT /frontview/ui/resource/html/COOLADDON
    /var/run/COOLADDON.pid
    /etc/frontview/apache/addons/COOLADDON.conf
    /etc/frontview/addons/ui/COOLADDON
    /etc/frontview/addons/ui/COOLADDON/COOLADDON_HANDLER.pl
    /etc/frontview/addons/ui/COOLADDON/COOLADDON.js
    /etc/frontview/addons/ui/COOLADDON/COOLADDON.html
    /etc/frontview/addons/ui/COOLADDON/language
    /etc/frontview/addons/ui/COOLADDON/language/ja
    /etc/frontview/addons/ui/COOLADDON/language/ja/COOLADDON.str
    /etc/frontview/addons/ui/COOLADDON/language/zh-tw
    /etc/frontview/addons/ui/COOLADDON/language/zh-tw/COOLADDON.str
    /etc/frontview/addons/ui/COOLADDON/language/en-us
    /etc/frontview/addons/ui/COOLADDON/language/en-us/COOLADDON.str
    /etc/frontview/addons/ui/COOLADDON/language/de
    /etc/frontview/addons/ui/COOLADDON/language/de/COOLADDON.str
    /etc/frontview/addons/ui/COOLADDON/language/fr
    /etc/frontview/addons/ui/COOLADDON/language/fr/COOLADDON.str
    /etc/frontview/addons/ui/COOLADDON/language/zh-cn
    /etc/frontview/addons/ui/COOLADDON/language/zh-cn/COOLADDON.str
    /etc/frontview/addons/ui/COOLADDON/language/ko
    /etc/frontview/addons/ui/COOLADDON/language/ko/COOLADDON.str
    /etc/frontview/addons/ui/COOLADDON/COOLADDON.xml
    /etc/frontview/addons/bin/COOLADDON
    /etc/frontview/addons/bin/COOLADDON/running.sh
    /etc/frontview/addons/bin/COOLADDON/start.sh
    /etc/frontview/addons/bin/COOLADDON/stop.sh
    /etc/frontview/addons/bin/COOLADDON/COOLADDON_service
    /etc/frontview/addons/COOLADDON.remove
  • The errors I posted above are bugs in the following files:
    For the image errors
    /frontview/dashboard/index.html
    /frontview/dashboard/dashboard.html
    /frontview/dashboard/wizard.html
    For the install errors
    /frontview/dashboard/legacy/addons/installed/installed.html
    /opt/installed/installed.html
    Okay I have found some problems in the SDK located http://www.readynas.com/download/addons/addons_sdk.tgz that was causing it not to work.
    addons_sdk\template\ADDON.xml
    <get_url>/addons/%ADDON%_HANDLER.pl</get_url>
    <set_url>/addons/%ADDON%_HANDLER.pl</set_url>
    should be changed to
    <get_url>%ADDON%_HANDLER.pl</get_url>
    <set_url>%ADDON%_HANDLER.pl</set_url>
    addons_sdk\addon.config
    RESTART_APACHE="n"
    RESTART_APACHE="y"
    There is one more issue where it does not save the runtime seconds into /etc/default/services file.
    I will look into that tomorrow.
  • Thanks, that works.
    This SDK uses
    <get_url>../addons/%ADDON%/%ADDON%_HANDLER.pl</get_url>
    <set_url>../addons/%ADDON%/%ADDON%_HANDLER.pl</set_url>
    which works and you don't need to restart apache.
    Funny though that the photo addon that is included with the readnas uses %ADDON%_HANDLER.pl and even the third party HTOP does as well.
    For some reason this SDK has commented out the code that has the "run time seconds" setting.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The "run time seconds" value isn't needed. It's just part of the example add-on.
ProSupport for Business
