super_poussin
Apr 04, 2013Virtuoso
Addons on R6
Hello Because it was disclosed most of you can installl addons without going on Genie, perhaps because you have R6 on old X86 Nases or for some other reasons. Please Guys, Note that Whocares and...
tiranor
Apr 29, 2013Aspirant
It should have /tmp on /c/ with warnings to prevent it from going over hundred of GB, too many apps use /tmp for their temporary content.
I have/had the same problem with php of 4.2, sometimes, ajaxplorer wrote the temporary file on /tmp instead of directly on the folder. I moved /tmp to /c/tmp and created a symlink, but i'm not really sure if it works perfectly.
