Lionelv00's avatar
Lionelv00
Subversion addon - connection refused
Hi all,
readynas ultra 2
I've installed the subversion addon from rnxtras. Now when I try to checkout I get connection refused. Here are the steps I followed:
On the readnas:
NetgearNAS:/opt# svnadmin create /opt/subversion/SVNTest
NetgearNAS:/opt# chown -R admin:admin /opt/subversion/*
On my local machine:
~> svn checkout svn://192.168.1.100/SVNTest
svn: E000111: Unable to connect to a repository at URL 'svn://192.168.1.100/SVNTest'
svn: E000111: Can't connect to host '192.168.1.100': Connection refused
I have EnableRootSSH installed.
Any ideas how I can get it to work?
  • Sorry for the late reply, still trying to get used to the new "forums".
    Actually, you were already close. You created the SVN repo correctly but the correct command to checkout a repo from the ReadyNAS would be
    svn checkout https://192.168.1.100/svn/SVNTest
    Two things to note here: For accessing the Repo you have to either use the HTTP or the HTTPS protocol, not SVN. And for the path to the repo you habe to prefix the repo's name with "/svn/".
    When pushing changes to the ReadyNAS you'll have to authenticate using a valid username/password combination as defined on the ReadyNAS.
    -Stefan
    • Lionelv00's avatar
      Lionelv00
      Thanks for the response. So seems the rnxtras subversion addon already added SUBVERSION.conf so the module was already loaded.
      After that, the command:
      # /etc/init.d/frontview restart
      Does not exist, it didn't matter anyway since svn was already loaded, but I ran maybe the equivalent?
      apache2 -f /etc/frontview/apache/httpd.conf -k restart
      But I'm still having no luck:
      svn checkout http://192.168.1.100/SVNTest
      svn: E120108: Unable to connect to a repository at URL 'http://192.168.1.100/SVNTest'
      svn: E120108: Error running context: The server unexpectedly closed the connection.
      svn checkout http://192.168.1.100/opt/subversion SVNTest
      svn: E120108: Unable to connect to a repository at URL 'http://192.168.1.100/opt/subversion'
      svn checkout svn://192.168.1.100/opt/subversion SVNTest
      svn: E000111: Unable to connect to a repository at URL 'svn://192.168.1.100/opt/subversion'
      Are there logs anywhere that might give clues?
      • WhoCares_'s avatar
        WhoCares_
        Mentor
        -Stefan
ProSupport for Business
