bizmate
May 18, 2017Tutor
Affordable hd cameras for ReadyNas 104 for Surveillance
I have seen several posts and tried to browse the list of supported cameras to get a reasonably cheap one for the ReadyNas 104. So far it looks like there is no standard and I could not find a singl...
JennC
May 19, 2017NETGEAR Employee Retired
Hello bizmate,
For now we recommend to use only the ones that are listed at this link.
Welcome to the community!
bizmate
May 19, 2017Tutor
Hi Jenn
as per initial post I had checked the compatibility list. This list is old (Feb14) but also is not practical. Some models cannot be found in the market and most are overpriced. It is very difficult at the moment to find a compatible camera with reasonable price. My question is for whoever has actual experience and specific model with price in mind.
- Nov 24, 2016Retired_Member
