ktw2017
Jan 17, 2017Aspirant
Amazon Cloud Drive does not sync anymore
Hello, I've been using Amazon Cloud Drive sync on my ReadyNas 6.6.0 for a couple of weeks, and it worked perfectly. 10 days ago, I've unfortunately switched off the service (under Cloud tab), a...
- Jan 19, 2017
The error log was complaining about checkpoint not found and the last checkpoint was 'xxxxxx' some string. I added that last checkpoint to /var/cache/fvamazon/checkpoint.
ktw2017
Jan 18, 2017Aspirant
That's not it. Before the deactivation / activation a new scan took about 25 min. Now, even after days, nothing happens and the process is running.
Darth_Vader
Jan 18, 2017NETGEAR Employee Retired
I would need to see the logs to find out what's going on. Can you PM me your logs?
