Zecaf
Oct 05, 2016Guide
Amazon Cloud still not working with 6.6.0
Hello, After upgrading I still have that bug: I go to cloud, I click on the "off" switch to put it "On" in the "Sync With Amazon Cloud Drive" menu. I get the Amazon page. Credientials are OK, I a...
- Oct 06, 2016
I have no indication about that on the page, just a list of services (that I couldnt use). But I did remember that the NAS couldn't check its firmware upgrades, and I finally found that the DNS needs to be added on the network cards... UI wise, this is kinda crappy, sorry to say that. ;) But now all is fine, I'm just really disapointed that I can't sync just a folder, i need to sync a whole share... :(
Anyway, thanks a lot for the answer / hint. ;)
Zecaf
Oct 06, 2016Guide
JennC
Oct 07, 2016NETGEAR Employee Retired
Hello Zecaf,
Thanks for getting back. Yes, there are times that DNS is the culprit of this kind of issue.
Perhaps you can post this being able to sync a subfolder with Amazon Sync as a suggestion at idea exchange board.
- ZecafOct 11, 2016Guide
Done. Well, I posted on something close enough and added my idea. ;) You need to boost that kind of feature to attract customers! :p
- JennCOct 12, 2016NETGEAR Employee Retired
Hello Zecaf,
Great!
To close this thread, please mark the appropriate post as a solution.
Feel free to post any suggestions, comments and.questions!
