Gran_Maestro
Aug 10, 2014Guide
Amule how-to
Hi there everybody, I wonder if there is anywhere I can find a how-to specific to the Amule version for ReadyNAS running OS 6.1.8 firmware. I installed the app no problem but there is no obvious wa...
fabNAS
Aug 31, 2014Aspirant
Hi, I have a ReadyNAS 312 using 6.1.8 firmware
I'm also trying to add amule app, it installs easily but once in the amule web interface it is not clear at all how to make it work. It shows no Server and says Kad not connected.
I've found the amule.conf file in the amule folder, I can edit it with notepad++ but I've no idea what should I change to make it work.
Anyone managed to use amule on OS 6?
Thanks
Thanks
