Gran_Maestro
Aug 10, 2014Guide
Amule how-to
Hi there everybody, I wonder if there is anywhere I can find a how-to specific to the Amule version for ReadyNAS running OS 6.1.8 firmware. I installed the app no problem but there is no obvious wa...
fabNAS
Jan 17, 2015Aspirant
Hi thanks, that is too complicated for my limited knowledge though :D
I had problems with the frontview which for some reason died so I just did the factory default reboot which sorted all the problems out, now my eMule works on the last firmware, no more error. I suspect though that it can happen again on some future firmware update.
