night_surfer
Sep 15, 2014Aspirant
amule installation and starting problem
Hi all, i've found a problem un my RN104: when i try to start amule (manually installed with the right arm package) the NAS system switch it off automatically after a few seconds and give me the fol...
night_surfer
Sep 16, 2014Aspirant
Hi, thanks for the reply, first of all.
Nas os is 6.1.8, the last one...
I think that if there is a problem on the internet connection the nas should not update also antivirus defenitions, and it has no problem doing this :( My internet connection quality is really good, it's a 4Mb down and 0.4Mb up, with a ping between 1 and 10 ms. It's wimax based and the isp node is fibre-cabled...
There are other features that can stop the automatic installation?
Also there is the problem that the manual installation goes well, but the application doesn't starts and give me that error code...
Thanks very much...
Thanks very much...
