night_surfer
Sep 15, 2014Aspirant
amule installation and starting problem
Hi all, i've found a problem un my RN104: when i try to start amule (manually installed with the right arm package) the NAS system switch it off automatically after a few seconds and give me the fol...
night_surfer
Sep 22, 2014Aspirant
Hi, I think the problem is not the firmware version, i'll explain:
I've performed a factory reset after installation of the first firmware disponsable (6.1.1). Performed the Factory reset i've installed amule manually from package for ARM. Amule started to work fine. After this (without change any setting or adding condivision) i did the reboot, and amule didn't work at all. so I have updated the formware at the last disponsable (6.1.9), removed amule and reinstalled it, but didn't work. So i did the factory reset a second time with the last firmware this time, installed amule and worked O_o. I did the reboot then and...surprise! it' doesen't works!...same error when i try to start it: 22002010000. I thought that was a problem of ARM-based app, but your NAS is intel based so it can't be... Someone knows Please wich is the problem for this error code??? I've noticed also that after the restart the amule application did not appear in the list of installed apps, the one which is in the main page. Is correctly shown in the list of installed applications in the tab "applications". I can't understand it...There is the developer or someone that can help us?
Thanks
Filippo
Thanks
Filippo
