night_surfer
Sep 15, 2014Aspirant
amule installation and starting problem
Hi all, i've found a problem un my RN104: when i try to start amule (manually installed with the right arm package) the NAS system switch it off automatically after a few seconds and give me the fol...
fabNAS
Sep 23, 2014Aspirant
Ok, I will avoid doing the Factory reset then, thanks Filippo.
Netgear support told me to contact the developer but I have no idea how neither I think he has any obligation to give us support on the issue.
"I appreciate your comments and suggestions but, I honestly think that it is the app developer who should keep up with the ReadyNAS. It is similar to any other products just for example, a software for Windows, if the software is not compatible with a Windows OS, it is not Microsoft who will going to adjust but the software developer. Same goes with the ReadyNAS."
I thought they should take more responsibility in making sure the apps work in their machine but they are probably right and the mistake was mine.
